I’d also like the option to display an SFTP window in the terminal connection, instead of having to create a separate SFTP window. When you change directories in the terminal, SFTP should follow automatically and optionally, vice versa, so changing the SFTP directory would send a “cd” command to the terminal.
Lastly, I’d like a full-featured internal file editor that supports syntax highlighting, etc… so we can select a file in SFTP and open it directly within Royal instead of having to switch to an external app. Many other terminal clients support these features.
