SFTP connections with Yubikey FIDO
I use Yubikey fido for ssh authentication. In Royal TSX it works for ssh connections with “run inside login shell”. For SFTP there is no such option and the login fails.
Is their a way to also have sftp connection running inside login shell?
Regards
Are you using Royal TSX on macOS or Royal TS on Windows?
On macos
Hi Olivier,
I will move your thread to the Royal TSX Ideas forum.
