My connections are requiring to use AgentForwarding option. I didn’t found that option in SFTP connection setup. Am I bling or it’s just not supported?
Michal
Michal
Hi Michal,
Agent Forwarding is currently not supported for SFTP connections and I’m not sure if we could add support for it.
Are you aware of any other GUI SFTP client that supports Agent Forwarding?
Hi Felix,
First, thanks for quick answer!
And second, unfortunatelly not. I’ve Tried FileZilla, but it does not support such option as well. On Windows I was using WinSCP which supports that. For terminal session I’m using custom script and passing it to SFTP by option ‘-s’, which enables AgentForwarding.
Would it be maybe possible to use option ‘-s’ withing the RoyalTSX?
Hi Michal,
for file transfer connections we’re using a 3rd party library from Rebex. See https://www.rebex.net/file-transfer-pack/default.aspx for more details.
As far as I can see, there’s no support for agent forwarding included in Rebex’ file transfer components.
Hi Felix,
I see. Ok, thanks, answer is sufficient, but unfortunately not pleasant. I’ll keep looking for other GUI SFTP client with that option.
Michal
