Set Custom Fields as Required Fields
I would like to see a way to make custom fields required to have content when
adding a new connection object. For example, when I
add an RDP connection, I have three custom fields: “Host Type” (vm or
physical), “Server Role” (domain controller, smtp, RDS, etc.), “Responsible
Person”. Additionally, if a custom field is set as “required”, it should appear on the main pop-up window when creating a new connection so that nobody has to go digging for them in the custom fields section.
When adding a connection currently, I just want to be able to
enforce those to be filled because most of the time I forget and I’ve
just got a whole bunch of servers in my list to manage. Makes it easier
as I can filter through the dashboard to find systems, etc. Also, I can see this as useful for shared files when working with a team.
