[RTS 6.1.60616] Sending CTRL-ALT-DELETE does not work with integrated TightVNC
I’m using Royal TS 6.1.60616 and the integated TightVNC plugin.
Clicking the “Send Ctrl-Alt-Del” button in the “actions” ribbon does not have any effect.
It does work when using the standalone TightVNC viewer (without Royal TS) though.
I guess this is a bug, or is the problem on my side?
Thanks and best!
Hi! Can you try the latest version of Royal TS V6 or the current beta of Royal TS V7?
Royal TS V6:
https://www.royalapps.com/ts/mac/download
Royal TS V7 Beta:
It works with v6.1.60731.
Best, Martin
