Royal TSX VMware connections
Can you please provide details on the usage of VMware connections in Royal TSX. I am not sure if I am supposed to make a connection to the vCenter server, an individual host, or an individual guest. So far, I have tried all 3 with no luck.
Hi Lee,
the VMware plugin supports connecting either directly to a host (ESX) or vCenter. A direct connection to an individual VM is currently not supported.
A common reason for unsuccessful connections is that you need to enter just the hostname, not a web URL to the host/vCenter.
Please let me know if that helps and if you still can’t connect, please go to “Preferences - Logging - File Logging”, enable “File Logging”, set the “Logging level” to “Verbose”, repeat the test and send me the generated log file.
thx,
