Retention field is too small for three-digit numbers
Just a small issue, the edit field in Options > Deleted Objects > Retention (in Days) has a width that only displays two numbers at a time. So if you enter 120 (i.e. four months), this will be displayed as “12” (the 0 is still there and you can reach it with the arrow keys on the keyboard but it is not displayed).
This can be confusing, especially if you work in a team (e.g. we have the 120 day rule for compliance reasons and a colleague just ask why we had this only set to 12 days)…
So if this field could be made a little wider that would be great!
Thanks.
Hi Johnnie!
Thanks for letting us know. This is indeed quite tight. I’ve fixed this for the next minor release.
