[REBEX] - X11 Forwarding
Does the rebex terminal plugin support x11 forwarding? If so, can it be implemented?
Hi Ryan,
rebex does not support X11 forwarding. As far as I know, there’s no plan to implement that either. For x11 forwarding you need to use the PuTTY based plugin or some other tool.
Thanks for the clarification Stefan.
