Here is my problem.
When I launch a terminal ssh session, at start, there is a warning message displayed. (this is a warning from my company from the server I connect to).
If I use a putty connection, the warning is displayed in the terminal window itself.
But when I use a rebex connection (which I need to use), the warning message is displayed in a popup and I need to click OK to close the popup.
My question is: is it possible to have this popup closed automatically?
Why this question? Because when I launch a ssh terminal, I have some startup tasks automatically launched. But they are launched only when I close the popup.
For one terminal, it is not a big deal, but I often open multiple terminals at once, and clicking OK on each popup is quite annoying.
I hope I’m clear.
Thanks i advance.
you can disable this popup in the Display Options “Show Pre-Authentication Banner”:
https://content.royalapplications.com/Help/RoyalTS/V5/index.html?reference_terminalrebex_displayoptions.htm
Many thanks. It works.
I passed all the time to find how to validate this popup, that I did not think we can avoid this popup.
Do you know if it is possible to have this option disabled by default when creating a connection?
You can change the defaults easily: in the Navigation panel, open the Application -> Default Settings node, select Terminal and edit the defaults. Ensure that rebex is your default plugin in order to see the rebex settings. Once you’ve set that up, all new connections will have the default settings you configured.
Thanks a lot Stefan. It’s perfect.
Have a nice day.
You’re welcome! Glad I could help!
