[REBEX] Name and order of text highlighting rules
When you have a lot of text highlighting rules or complex expressions, it would be useful to :
  • choose the execution order (add an arrow to move a rule up or down)
  • be able to give rules a display name (currently, default rules and imported rules have a name, but no name once applied). For example, the “IPV4 Address” rule is complex and it would be useful to add a “Name” column before “Regular Expression”.
Thanks for the feedback. I will check if this can be implemented.
Hi Damian,
I added a name field as suggested. For the order, I had to use the grid’s context menu because the UI is already quite busy. Stay tuned for the next release.
