(Royal TSX 3.2.1, Remote Desktop FreeRDP 3.2.4)
When an attempt to RDP to a host fails, regardless of the underlying cause, the overly vague error message is popped up: “The connection failed. (Error Code: CONNECTERROR)”. Greater detail on the cause can be found by events in the log viewer, however this is tedious. I would prefer to have slightly more detailed error messages, so that I may more quickly respond to issues of hostname resolution or host reachability.
I’ve enumerated a handful of scenarios that result in the vague error message that I had mentioned. I’ve also included additional notes on what I might find in the log viewer, as well as a description of the desired behavior/error message.
Mike
Hostname Resolution Failure
Example: foo.bar.com cannot be resolved to an IP address
Current behavior:
- Popup error “The connection failed. (Error Code: CONNECTERROR)”
- Log Viewer message “getaddrinfo: nodename nor servername provided, or not known”
Desired behavior:
- Popup error indicating that the hostname “the hostname” could not be resolved to an IP address.
Connection Refused (TCP service is not listening on the remote host)
Ex: Attempting to RDP to a windows computer on TCP 12345
Current Behavior:
- Log Viewer message “BIO_should_retry returned a system error 32: Broken pipe”
Desired behavior:
- Popup error indicating that the host “the hostname” refused the connection.
Connection Timeout
Ex: Attempt to RDP to 1.2.3.4 on TCP 3389
Current Behavior:
- Log Viewer message “failed to connect to 1.2.3.4”
Desired behavior:
- Popup error indicating that the attempt to connect to “the hostname” timed out.
User does not have the right to sign in via Remote Desktop Services
(example: user does is not a member of the Remote Desktop Users group)
Current Behavior:
- Log Viewer message “BIO_read returned a system error 54: Connection reset by peer”
- Honestly, I believe that this issue lies more with FreeRDP than with Royal TSX
Desired behavior:
- Popup error indicating that the user lacks the necessary permissions to RDP into the remote host.
