RDP Connections using th Secure Gateway
I’ve setup Royal Server and the Secure Gateway. I added a RDP connection to the Windows Royal Server with the gateway set. It works fine. But if I added any other server that’s not the Royal Server, the RDP connection won’t connect. Maybe I’m using it wrong or missing something? I was hoping to connect to servers without a VPN while using Royal Server and the Secure Gateway. Is this possible?
in general this is the use case for the secure gateway. I’m not sure how your setup looks like and I kindly ask you to open a support ticket with screenshots of your configuration to further assist you.
