Say that you need to keep remote resolution to a Custom size, 1920x1080.
Say that you are connecting to remote using fullscreen mode with a mac (client) resolution as 2048x1280 HiDPI.
If you use in Display Options - Resize Mode: Scrollbars, the remote screen will center in the client screen. If you set Resize Mode: Smart Sizing or Smart Reconnect, the remote screen will align to lower left corner of the client.
It is possible to have remote screen centered in all resize modes?
Refer to ticket #63287 for further details. Many thanks.
