[Putty] Copy / Paste Shortcuts Support (Ctrl+Shift+C / Ctrl+Shift+V)
Hello
Putty (>=0.71) has shortcuts for Copy and Paste from clipboard actions:
  • Ctrl-Shift-C - for copy
  • Ctrl-Shift-V - for paste
They are disabled by default.
To enable them users should set “Window > Selection > Ctrl + Shift + {C, V}” to “System clipboard”.
Please add the support of this feature to Royal TS.
Users of other terminals (ZOC for example, Linux terminals) who have been using these shortcuts for years have discomfort on migration to Royal TS.
Thank you
I implemented those settings now in the latest beta:
https://www.royalapps.com/go/kb-ts-win-downloadbeta
You can find it under Advanced -> Input -> Clipboard.
Hi Stefan
I have tested 5.1.10912 and it works perfectly!
Thank you very much.
Mykola
Thanks for testing the beta. I really appreciate it!
Hi Stefan, could the same be accomplished somehow for Rebex?
Putty causes the whole RoyalTS to crash on the Surface Pro X devices, but Rebex works well.
Only real issue is that I can’t get myself to start using a mouse (right click) for copy-paste and used CTRL+SHIFT+C (or+V) for way over 20 years now.
Would love to continue to use RoyalTS and roll it out within the company, but this little annoyance is actually a deal breaker.
Robin
Hi Robin,
thanks for the feedback. I will write it down and hope we can do something about that in Royal TS V6.
Hi Stefan, has there ever been a solution implement to assign some sort of copy-paste shortcuts to Rebex sessions?
Thank you,
Robin
Hi Robin,
this is a feature related to PuTTY. If you want to see something similar for Rebex, I kindly ask you to create a new feature request in this forum.
