i have keys working via PrivateKeyPath and am now trying to implement keyfiles as content.
https://docs.royalapps.com/r2023/scripting/objects/organization/royalcredential.html#privatekeypath
> PrivateKeyContent
> Type: byte, Default Value: new byte { }
> Assign a key file to the credential by embedding the key file’s content.
now i need a PowerShell code example on how to use the content of one of the cert files (that i am using successully via PrivateKeyPath).
Hi Falk!
I responded on Mastodon already but maybe it got lost somewhere. Can you check if this helps you to set the byte array:
https://stackoverflow.com/questions/10672092/read-parse-binary-files-with-powershell
my answers here from mastodon via auto translate :
"@royalapps@dotnet.socialthat’s unfortunately not what I’m looking for. I have my problem here: https://docs.royalapps.com/r2023/scripting/objects/organization/royalcredential.html:
“PrivateKeyContent
Assign a key file to the credential by embedding the key file’s content.”
I can’t do anything with that part of the documentation, unfortunately. How do I get a format like that - it’s surely been tested?"
“It works via PrivateKeyPath with a path to exactly the key files that I want to use via PrivateKeyContent.
I can leave it like that, but if you can tell me how to do it via content, I would prefer that :)”
so. no. the link provided did not have a solution for.
i would appreciate if you could provide me with an example
“now i need a PowerShell code example on how to use the content of one of
the cert files (that i am using successully via PrivateKeyPath).”
that way i could figure out the rest. i would also provide the soultion (my code) here
Sure, here’s a simple example:
Install-Module RoyalDocument.PowerShell
Import-Module RoyalDocument.PowerShell
$RoyalStore = New-RoyalStore -UserName ($env:USERDOMAIN + '\' + $env:USERNAME)
$RoyalDocumentPath = Join-Path -Path $env:USERPROFILE -ChildPath ('Documents\' + $env:USERDOMAIN + '.rtsz')
$RoyalDocument = New-RoyalDocument -Name $env:USERDOMAIN -FileName $RoyalDocumentPath -Store $RoyalStore
$Credential = New-RoyalObject -Folder $RoyalDocument -Type RoyalCredential -Name "Credential with KeyFile"
Set-RoyalObjectValue -Object $Credential -Property UserName -Value "user1" | Out-Null
# set to embedded private key
Set-RoyalObjectValue -Object $Credential -Property PrivateKeyMode -Value 1 | Out-Null
# read key content as shown here: https://stackoverflow.com/questions/10672092/read-parse-binary-files-with-powershell
$PrivateKeyPath = Join-Path -Path $env:USERPROFILE -ChildPath ('Documents\test.pri')
$Bytes = [System.IO.File]::ReadAllBytes($PrivateKeyPath)
# set the private key content
Set-RoyalObjectValue -Object $Credential -Property PrivateKeyContent -Value $Bytes | Out-Null
# depending on how your key is set up you may also need to set the Passphrase
Set-RoyalObjectValue -Object $Credential -Property Passphrase -Value 'secret passphrase here' | Out-Null
Out-RoyalDocument -Document $RoyalDocument
Close-RoyalDocument -Document $RoyalDocument
I hope this helps.
Perfect, works great! Thanks!
You’re welcome! Glad I could help!
