Opening File menu sometimes resizes RDP connection
This seems to happen randomly, but I noticed if a RDP tab is active while opening the File menu, the RDP connection seems to resize (which may trigger reconnection). And every once in a while, after closing the File menu, the connection will remain tiny:
When this happens, are you using the “Backstage” view (which covers the whole app content)?
I’m not aware there’s any other way the File menu can open.
On the Home ribbon tab you also have buttons to open a file, for example. So you don’t have to always use the Backstage view (depending on the task). That’s why I’m asking. Confirming that this happens when using the Backstage view is a strong clue. I will investigate.
Ah, I only open the File menu to go to Options or Plugins (or to look at current build number when reporting problems).
I think I found the root cause for this. The next beta will have a fix. Please let me know if it still happens.
