Nothing works after upgrade to 3.3 on macos
macos version = 10.13.4
I choose to open my existing .rtsz, no response on on the UI. try to new a document, after I input all necessary field, and click apply, no response. Whatever you did, you get nothing on the tree list …
License shows: Active
Help! can not go without it!!!
Hi Jun,
as stated on the top of the navigation panel (sidebar) your objects are filtered by favorites.
To disable this please click the yellow star button on the bottom of the navigation panel.
best regards,
thank you to answer my stupid question.
