Nested Secure Gateways
For me it’s working great too, so it’s very helpful now :slight_smile: Only small issue is when I try to test newly created nested gateway, because I’m getting error message that configured gateway is not available. But when I use this gateway, everything works fine. :slight_smile:
Hi Tomas,
perfect, thx for letting us know!
Regarding the issue you’re having: The “Test” button currently only does a simple port-check on the target host. You’re in that it doesn’t evaluate if a chain of tunnels is valid. If you’d like to see this extended to a more thorough testing technique, please file a new feature request.
thx,
