In V5, when searching for items in the Navigation pane, we could enter the exact name of an item and press ‘Enter’ to connect.
In V6, it now does not select the item.
It is possible to change this behaviour?
Thank you
Max
Thank you
Max
Hi Max,
we had to change the behavior slightly because automatically focusing the first found connection during search could lead to focus issues when the connection’s dashboard is loaded. The change is not dramatic though. When you search for a connection and hit ENTER in the search box, the focus is changing to the navigation tree and there we will focus the first matching connection. So, hitting ENTER twice should do the trick.
Thank you for getting back to me. I just figured it out and came here to say!
Max
Hi Max,
thanks for the follow-up, glad this worked for you.
Have a great day!
