Missing Keystrokes VNC
I use a VNC connection to an ADDERLink® ipeps+.
https://www.adder.com/en/kvm-solutions/adderlink-ipeps-plus
With RealVNC the problem does not occur but with Royal TS and the integrated VNC client I have the following problem:
Some keystrokes are not transmitted. Keys are getting lost. Sometimes a key hangs and continuously sends a keystroke.
After I have entered an @, I have to rebuild the connection.
I also own Royal TSX. Everything works without any problems there.
Do you have any idea what the problem is?
Hi Marc,
on Windows we integrate TightVNC and UltraVNC - which is also available as a standalone app/viewer. Can you tell us if the standalone apps are working as expected or do they exhibit the same behavior?
I have the same problem.
If I tip \ I loos the connection to my keyboard. After pressing left ALT und waiting for a second it’s again connected.
Also after some other keystrokes I loos it but couldn’t figure out which.
VNC Connection default setting, with UltraVNC it opens just in a external window with following message. In UltraVNC I don’t loose the connection. ThightVNC I havn’t installed.
By the way, If I start a VNC connection in Royal TS, all other Connection are closed.
Royal TS Version: 7.2.50703
Regards
Eric
Hi Eric,
what happens if you use Tight/Ultra VNC standalone app? Do you see the same issue?
If i use the Ultra VNC standalone App everything is fine. I can type everything without loosing keystroke and other connections don’t disconnect.
Eric
I’m not able to reproduce the issue. May I kindly ask you to open a support ticket as we probably need more information.
I have simmilar problem.
when typing keys in integrated TightVNC, some keystrokes are “catched” by Royal TS. Very often it switch to another session window, which is very annoying.
TomasZ
We aren’t able to reproduce the issue and need more information or some good repro steps in order to further investigate.
