I’d like to have a menubar icon including a drop-down menu with my connections. Maybe also the option to just show the favorites if the connection list is too long.
There’s the same idea for the windows version under Context menu for systray or taskbar
Peter
Hi Peter,
while we don’t currently offer a menu bar item, the context menu of the dock icon shows a list of your documents and contained objects and can be used to launch connections too.
Does that help?
Felix
Hi Felix,
I’d prefer a menubar icon, and there should be an option to remove the dock icon.
Peter
