I am also migrating from mobaxterm and found the exact question I had on the Windows side.
I have wondering if default templates exist for MacOS version?
Thanks in advance.
Thanks in advance.
I think I just found it..
On the connection you want to work on Properties > Advanced > Triggers > Action : Highlight Text then Regular Expression > Templates. Worked
source that helped me Adding default pre-defined text highlighting templates
