Logging settings by platform
Currently, I flip between the macOS and Windows applications. Since you can only have one logging destination set per entry, logging always fails on the opposite platform because of the path differences.
I’d like to request an option to store a Windows and a Mac logging path. Whichever version of RoyalTS you’re currently using, that path will be used.
Maybe the current text box would be treated as the “default” and then there would be a checkbox that says “Log Path by OS” and then it would reveal the Windows and macOS path fields.
Same request in the macOS idea portal:
Hi Tim,
can you provide more details on where you want to differentiate the logging paths based on the platform? Which plugin or connection type are you referring to?
