Keyboard shortcut keys focus on a external window mode
I’m using externals windows to access virtuals machines in my company to have quick access to both taskbars, of my computer and the virtual machine, but this way i don’t have “keyboard focus” in this “window mode” to use the keyboard shortcuts on the virtual machine, for example ALT+TAB, WIN+R etc..
I’d like to have any option in this “window mode” that will give keyboard focus to the external window i’m using, this way i will be a lot more efficient doing my work.
Thank you four your consideration
Regards
you can enable Windows Key Passthrough in the Input options of your connection to make WIN+R and ALT+TAB work:
https://content.royalapplications.com/Help/RoyalTS/V4/index.html?reference_remotedesktop_input.htm
Let me know if this works.
Thank you, indeed this works perfect
You’re welcome! Glad I could help!
