Hi.
I noted a bug with keyboard on MacOS Client when RDP Connection. When i press the key below, it not work as expect.
Downloading SharpKeys app to map key, when i press the key it says "ISO extra key (00_56). I tried to map to expect key, as shown below, but didn’t worked.
Equipment is MacBook Air M5 With Default US Keyboard and Tahoe 26.6.2. Tried with Royal TSX beta version 26.0.11 too.
Hello Mauricio,
I tried reproducing the issue but was not able to.
I connected through a US keyboard Macbook to a Windows 10 machine and both the ` and ~ symbols are sent correctly.
I do not have any Custom Keyboard layouts set in the Advanced > Input section of the RDP connection:
and the keyboard layout on the remote system is set to EN-US:
Can you please check which keyboard layout is set on the remote system and if configuring a Custom Keyboard layout in the RDP connection settings helps resolve the issue?
Hi Christoph.
Thanks for the fast reply!
I hadn’t changed the option in Advanced > Input, and my remote system was configured for a US keyboard.
Even after a clean macOS install, running Royal TSX with default settings, and connecting to a fresh machine via RDP, the issue persisted.
After some troubleshooting, I found the fix: my macOS system language and keyboard layout were not set to US. Changing the keyboard layout to US solved the problem.
Thanks again!
Hi Mauricio,
thanks for the follow-up and I’m glad you were able to find the fix and this is working for you now!
