Key Sequences, Saved Credentials & Lockdown
Wondering if anyone else has experience this behaviour.
I have a few Key Sequences setup for some web pages that the Auto-Fill doesn’t work for.
When the document is in lockdown mode (passwords hidden) the Key Sequence spits out “$EffectivePassword$” when it is referenced in the Task rather than the actual password.
When the document is unlocked, the sequence works as expected.
I understand the Key Sequence could compromise the password, but that isn’t the issue here.
Surely this must be a bug?
Hi Emile,
this is not a bug; this is actually by design! There are a few restrictions that apply when a document is locked down to ensure that passwords cannot be easily obtained, one of them being:
Secure properties (such as $EffectivePassword$ or $CredentialPassword$) are not resolved in command tasks, key sequence tasks, connections or templates.
​You can find more information on this topic here: https://www.royalapps.com/go/blog-ts-documentlockdown
Sorry to be the bearer of bad news!
Thank you. I had a read and fair enough.
Still disagree with the premise. At the very least it should be an option in the same window where you set the lockdown passowrd. There are some enviroments I work with where this would still be favourable over the extreme alternative of exposing all other passwords. Seems like an all-or-nothing approach.
While I do understand that this is by design to not read passwords in plain text it’s a bit annoying to leave the user alone at figuring out why something doesn’t work.
I’d really appreciate this being changed to an error or warning popup saying something like “This Key sequence tries to paste a passphrase from a locked down document which is not allowed due to security reasons, the phrase $EffectivePassword$ will be printed instead. Continue?
Thank you for the feedback, Stefan. I will see what we can do about that.
