jQuery - Web Page Autofill
Dear Team,
I have now tried several times to use the Web Connection with your Auto Fill. Login with username, password and then click on login is no problem. However, when I want to address multiple click elements with a jQuery selector, the whole thing doesn’t work anymore. The goal would be to press another button(s) on the page after login. I am aware that the KeySequences exist, but you cannot access a KeySequence in the personal document from a RoyalServer document. This would result in ~8000 additional objects in the document which would be neither good for performance nor for the GUI.
Thanks as always for your answer and best regards,
Moritz Wolf
A1
7.3 beta is available here:
https://www.royalapps.com/go/kb-ts-win-downloadbeta
We created a new/better way to configure auto fill using the actual connection. Docs are not updated yet but essentially you just connect to your web page connection, enable Auto Fill Configurationin the Actions ribbon tab to show the new configuration UI. When you see the login page, click the first button to Scanthe web page for elements. Then you can just hover over the login form elements and use the + icon to create a new auto fill configuration.
Would be great if you can test that feature and provide feedback.
