Issues with FreeRDP and OpenVPN
Hello all,
I have Royal TSX running on an MBP with M1 Pro. I also use Royal TS on Windows. In both versions I use databases synchronized via Nextcloud. So far so good, everything is working fine. As soon as I move outside my network, I have to turn on VPN to connect to my servers at home natively via RDP or SSH, I think this is a normal scenario for many.
Once I have VPN turned on, I can connect to my Linux systems via DNS names over SSH normally. (Native via the terminal as well as Royal TSX via iTerm2 plugin).
I assume by this working that my configuration is basically fine.
If I now try to connect to my Windows based systems via DNS name and RDP via VPN and Microsoft RDP App everything is fine. However, if I now try to connect to a Windows based system via RDP using the FreeRDP plugin via DNS with the same Royal TSX Config that I use for SSH, I only get the message - FREERDP_ERROR_CONNECT_TRANSPORT_FAILED.
If I do it at the same time via the Microsoft RDP app without making any configuration changes, I can connect immediately.
I have already cleared the DNS cache via terminal with “sudo dscacheutil -flushcache; sudo killall -HUP mDNSResponder”, because I thought it might be the problem.
If I do the whole thing without VPN in the corresponding local network, everything works fine. Only with open OpenVPN I have problems with Windows based systems via the FreeRDP plugin.
If I adjust my Royal TSX database and use the IP address instead of the DNS name then it works fine with an open OpenVPN connection. Because I use Royal TS/X also for work and there also OpenVPN is used I strongly prefer to use DNS names because I don’t and can’t use fixed IP addresses in every environment.
I believe that the workaround (disable TCP keep-alive) described in the following link will resolve your issue:
https://www.royalapps.com/go/blog-ts-mac-rdp-vpn
Please let me know if this helps!
Hi ! MY TSX worked fine until last week. Since this time I have been receiving this issue, I tried to fix with TCP keep alive, but not help :(. Could you help me? (Apple M2 Sonoma 14.6.1)
Hello, However my TSX were working, since the least 6 days it hasn’t been working. Today I tried to use this workaround, but it wasn’t help. I want to connect with RDP to a windows pc. Could you help me ?
Hi Gabor,
can you please test if using the latest Royal TSX V6 Beta, which can be downloaded here, resolves the issue for you:
https://www.royalapps.com/go/kb-ts-mac-downloadbeta
In case the issue persists, please open a new support ticket via the following link, so we can assist you directly:
