InPrivate browsing for web pages
I need to have pages that do not use Windows integrated authentication.
Usually I go with InPrivate browsing outside Royal TS, but it would be nice to keep all the webpages I need in RoyalTS so I can use autotype feature.
you can switch to the Chrome based web page plugin and use a dedicated “Engine”. This would be similar to “Incognito” or “InPrivate” mode because after you close the tab, all browsing data is deleted.
https://content.royalapplications.com/Help/RoyalTS/V4/index.html?reference_webpagechrome.htm
Thanks, it works brilliantly!
This should be something worth documenting somewhere.
Matteo
Glad that helped. I will see what we can do to make this easier to discover. If you have any suggestions, let me know. Feedback is always welcome!
