Why don’t you implement the connection types to into the app instead of exporting them to external apps?
At least for the most commonly used it should be done.
- RDP
- VNC
- SSH
I am working on integrated SSH connections. The problem is, that there is no library which does that for iOS (as there is for Windows). I have to implement everything on my own. And that’s simply a lot of work which will most probably never pay back.
But as I said, I’m working on it. So stay tuned.
Curious what the status is of this? Feels like it’s a bit broken at the moment since the other apps you call doesn’t support links with username and password. Or what external apps are recommended that works more seamless wtih royal? Love the idea of having it running on my ios device as well since I cannot live with out it on my computer.
Yeah. Just hit the same thing with VNC connecting to a Mac from Ios.
