Hello ,
i have this Setup from Windows but i if i start the Setup from RoyalTS 5. (or 4.) then i become the Dialog “Prepare to install” ….. but no more …..
Please help .
Hello ,
Please help .
Hi Uwe,
we haven’t heard of any issues with the installer. A couple of things you might want to check:
check if the installer was downloaded completely.
You can find the file hashes here: https://www.royalapplications.com/go/kb-ts-win-previousversions
temporarily disable AV/security tools to ensure they do not interfere
check the Windows Event Log for information why the installer might not start
try to install with a different user account or on a different machine
I hope this helps.
