Hyper-V VM Comment
Each Hyper-V VM has a name and a description aswell.
Sice we use the Description Field to display what is the purpose of a VM,
I need to open first the normal Hyper-V Manager, check the correct vm before
I can use Royal TS to connect to it.
Hi Patrik,
are you referring to the “Notes”? To be sure, can you post a screenshot?
Also, when you show the Details Panel, you will see the content of the Notes:
Yes, I was meaning exactly tis notes, I did not know about this part there.
Unfortunatly it throws an error when I try it, In both WMI and CIM Mode.
Hi Patrik,
can you please open a support ticket here with the two screenshots:
Please also include the Hyper-V server version you are using so that we can try to reproduce the error on our side.
Thank you,
