https://docs.royalapps.com/r2023/royalts/reference/tasks/key-sequence.html#sequence
I want to disable the replacement token/command popup when entering $ or { in the key sequence broadcaster. I regularly use the KSB as my “quick notes” to edit quick commands that I’m testing through my day to day. I still use tokens for some functions but those are more manually called upon, I have no interest in having RTS suggest/auto-complete them for me.
I’m on RTS 6.1.50425
