According to this page it’s in the folder right-click menu, but it’s not there for me.
There are instructions for Windows in the help, but I can’t find corresponding help pages for OS X.
How can I create templates on OS X?
Hi Andy,
while in the “Actions”/context menu hold down the ⌥ (option/alt) key and you’ll notice that the “Add” menu changes to “Add new Template”.
Hope that helps!
Thanks Felix, that was it.
You’re welcome, Andy! =)
