is there a way to create a credential object that remains invisible (or hidden) for users without admin rights, so they cannot view the username or password, but can still use it?
Thanks in advance!
Thanks in advance!
Hi Josua,
I believe that you are looking for our Lockdown Feature. You can find more information on this topic here:
We would also use Royal Server if that helps as part of the solution, but not as a Secure Gateway.
