Fullscreen-Mode without the tab on top
It would be a great feature if you could use a mac-vnc-connection in fullscreen mode without the tab on the top, just like it would be the native screen
Good news! This is now supported in the latest Royal TSX V3 beta which you can get here as always: https://www.royalapplications.com/go/kb-ts-mac-downloadbeta
This feature is broken into multiple sub-features:
* All connection types can now be configured to open full screen or in an external window. You can set this up in the “Window Mode” properties of your connections.
* All connection types now support ‘Connect with Options - Full Screen’
* And there’s a new setting: ‘Preferences - User Interface - Connection Tabs - Show Tab Bar in External Windows’
Unchecking ‘Show Tab Bar in External Windows’ doesn’t work.
Works fine for me! What exactly happens when you disable the setting and open a connection in a new window or full screen? A short video would definitely be helpful in figuring out what’s wrong.
thx,
