After having a SSH active connection based on user/pass credentials, by executing on the ribbon:
Home -> Connect with Options -> Connect using SFTP
the application will come up with a warning:
The authenticity of the host ‘…’ can’t be estabilished.
The fingerprint is ‘…’
Are you sure you want to continue connecting? Yes/No
The problem is that there is no way to save the fingerprint to dismiss this warning forever for this “subconnection”.
A solution would be to replace Yes/No with a
Yes always / Yes once / No
(or alternatively add a checkbox with “save fingerprint” )
Yes Always (or checkbox checked and pressing Yes) would store the fingerprint of the server and prevent this rather annoying dialog to appear again in the future for such connections.
