With the new Find in Documents interaction with the pop-over navigation pane, I’m finding that when I do need to manually interact with the navigation pane, my previous search is limiting the view inside of the pane.
Could the contents of the search field be cleared after an event or a delay? For my usage I would be fine with clearing after using Cmd+Enter to connect based on a search result but I do not know if that would be the best time for others that use the search.
Thanks for considering this.
