Feature Request: Powershell prompt for Inputs
When having a powershell connection it sometimes would be really helpful if instead of prespecifying all parameters having a popup appear with an input box where you can supply a parameter value. Sometimes it’s just not possible to make a new connection for every possible parameter value. That’s why I think it would be great if RoyalTS will can ask the user for dynamic inputs.
Kind regards,
Patrick
Hi Patrick!
Thanks for the great feedback. I agree, a prompt window would be a great feature and I will put that down on the list.
What you can also do is to bring up the script panel once you are connected (using the Actions ribbon tab). There you can change the parameters of the script on the fly and hit refresh to re-execute the script again. Maybe this helps.
