Feature Request: Iterm2 more settings!
Hello there,
in order to be able to use things like Powerline we need to be able to use text settings (see attached screen shot) from iTerm2 like the one called “Use built-in Powerline glyphs”. Even better for me personally would be an option where you can just import all settings from iTerm2 and make them default for the iTerm2 plugin.
Kind regards
Maciej Skrzetuski
Please add ability to remap modifiers on terminal plugin like you added on RDP
