Feature request : advanced tasks
I would like to be able to create subtasks
For exemple on an RDP connection, create a task (Update) under this server
Or a task under a task : task reboot under task update.
It would be verry helpfully for most of our projects, all the informations would be on the same place.
Kind regards.
Similar feature request / duplicate
