In macOS Terminal you can hold ALT key, draw a rectangle selection and only copy the text within the rectangle - see screenshot attached.
Could you add support for this to TSX’s Terminal Connection, please?
in Royal TSX (and standalone iTerm2) this feature is available by holding down both, the option/alt and command keys and dragging with the mouse/trackpad.
Hope this helps!
Nice one, cheers Felix!
