Enable Logging automatically for RoyalTSX
I used to use Royal TS for windows and switched to a MAC. One thing I loved was the autologging (recording) of SSH connections. Is there a way to do this automatically on MAC? I see the “Start Logging” option but would like this to happen automatically every time I start a SSH connection.
you can enable automatic logging in the “Logging” properties of your terminal connections.
Hope that helps!
Ahh thank you. I was looking for a application setting for this.
does that affect any properties that are for windows? Since it is a connection property if I change it does it affect windows logging and people opening the document on a windows computer?
No, the logging settings for macOS and Windows are separated.
Is there a way to set logging by default for all terminal sessions? Having to remember to enable this when creating a new session seems counter intuitive.
Hi Carlos
To make sure all future terminal connections have settings configured, please edit the Terminal Default Settings, found in the Navigation Panel under “Application - Default Settings - Terminal”.
Furthermore, if you need to change this setting for multiple connections, I suggest that you use our “bulk-edit” feature. To find out more about it, please refer to the following link:
https://www.royalapps.com/go/kb-ts-mac-bulkedit
best regards,
