Display custom favicons from imported KeePass files
KeePass 2.x supports using custom icons/favicons for folders and credentials. Currently in RoyalTS, when a KeePass file is imported it will only show ‘standard’ icons.
Cheers
Hi Frank!
Thanks for the feedback. I’m not sure this can be implemented but I will look into it.
you can test this feature in the latest Royal TS V7 beta:
https://www.royalapps.com/ts/win/features-beta
Looks great, thank you!
Thanks for reporting back!
