Custom field as a part of the displayed connection name
I created a folder with a bunch of machines. I need to replicate the whole folder multiple time (IP for the connection is already in the custom field, so I may easily change it for each group of servers), but the problem is in the title of these connections - it is not possible to use the variable there. Any chances to add such feature?
Or there is a way already and I just couldn’t find it…
Hi Jakub,
token resolution in the display name field is not planned but let me refer to this discussion:
Having a custom display name for tabs using replacement tokens is on the roadmap for V6.
