[CREDENTIALS] Allow a credential password/key to be saved for current session only
The scenario I envision is keeping a credential saved in the document, but without the password or private key saved. This will allow you to assign credentials to connections and be prompted the first time you use them. This functions now, but It would be useful if the password/key could be saved for the remainder of that RoyalTS sessions without it being saved in the document.
At the moment you can opt to just not save the document when you quit, but you’ll lose any other changes you made as well.
