Have a template which has “Specify a credential name set to an existing credential”
In the template use $this.EffectiveUsername$"
From a connection do “Connect with template” and use this template.
=> $this.EffectiveUsername$ gets correctly resolved to the chosen credential.
Have a template which has “Specify a credential name set to ?”
You get the Credential Picker menu => you select a credential
=> $this.EffectiveUsername$ does not get resolved to the chosen credential.
This was already discussed with support but they see this as a feature request and not a bug. This is why i create this here.
