We would like to be able to copy the password that was used for the connection.
This would allow us to easily run any commands regarding “sudo” or similar applicatios.
I have a dynamic credential. I can right click on it to open the context menu and moussing over “Copy to Clipboard” shows the options, “Copy Username” and Copy Password".
If it’s a connections $EffectiveUsername$ or $EffectivePassword$, these variables can be used in a key sequence task to type them in to the remote session, or you could copy the credential via the context menu of that connection object to get it on the clipboard of your local computer.
