would be great to have the possibility to open the properties via connection tab.
Hi, if the tab is active, you can open the properties using the Edit -> Properties command. If you want to have this task always visible, you can put it on the QAT (quick access toolbar) by right-clicking the command and selecting the option.
thanks, though is up to your decision it has all logic to get the possibility to have to access the properties at tab for quick access…anyway just saw that can use combination key.
