Have you considered allowing a regex-based search for the connection search filter?
Whilst clearly not essential, sometimes I find I want to work with a subset of available connections and their current connection names have no common elements.
This would be SUCH a helpful feature for me. For example, something happens with an application server cluster. I need to access the servers behind that cluster and the load balancer in front of it.
Current state:
lb and connect.cf, and ap, and cms, because those are server names of affected application. These are 3 separate searchesDesired state:
^(lb|cf|ap|cms), which brings up all the servers I need to accessYep, this would be very helpful in cutting down the clutter in the Navigation pane when working on a subset of connections
